striker-4age
posted on 20/10/12 at 12:43 PM |
rear fog light ?
hi there
do i need a rear fog light on my kit car ? to pass an mot ?
many thanks
striker-4age
Ben_Copeland
posted on 20/10/12 at 12:53 PM |
Yes you need a rear fog light
Its also pretty silly not to have one...
[Edited on 20/10/12 by Ben_Copeland]
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
renetom
posted on 20/10/12 at 03:18 PM |
light
Definitely yes, as Ben said
As most kit cars are very low, it'd doubly important to be seen in the fog.
Also a high level brake light on the roll bar is a good idea.
good luck
René
snowy2
posted on 20/10/12 at 05:52 PM |
Fog lights are the one thing i would ban tomorrow, they serve almost no useful purpose and represent a bigger hazard than the safety they provide.
The highway code says they should ONLY be used when the visibility in FOG (not mist or rain) is less than 100 meters i.e. about 1 or 2 times a year.
most drivers seem to think they must go on at the first sign of a misty day and stay on for a week at least. by and large the are as useful as a
chocolate fire guard.
However the powers that be seem to think they are a good idea so we are stuck with them, i never use mine.... even in thicker mist.
sometimes you are the pigeon, most of the time the statue.
posted on 20/10/12 at 06:09 PM |
Plus 1, I must agree, it really pisses me off when it starts raining and rear fog lights come on.. and front ones when its dark??? Its against the law
but does any twit get done?
stevegough
posted on 20/10/12 at 06:47 PM |
YES - you do need a fog light. It also needs to be the correct made-for-purpose lens as that lens sends out a parrallel beam as opposed to a wide
spread all the other lights do. It is important to position it correctly - the lens has to be at 90 degrees to the road so the pencil beam goes
towards following (ground) traffic - not air traffic! It also needs to be separated by so many cms from eg. the brake light.
Check the details in the manual carefully (It was one fail point in my IVA - I had used a light with the wrong lens).
____________________________________________________________________________________________________________________
Quoting snowy:
_____________________________________________________________________________________________________________________
Whilst I agree wholeheartedly with your points about the various muppet uses of foglights, they are 100% essential when in THICK fog - if you say they
serve no useful purpose, you must never have driven in serious fog - I mean when you can't see the kerbs, the road markings, etc.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
posted on 20/10/12 at 06:53 PM |
Living in East Anglia (fog capitol of the world) I wouldn't be without rear fog lights.
There are various sensible solutions to the fog light problem - in an old Toyota of mine, the fogs were switched on with a push button. As soon as
the ignition was turned off, the fogs reset to off. Later on I had a Ford Focus - that had a switch tied into the headlights - you couldn't put
the fogs on until the headlights were turned on, and once you turned the ordinary lights off the fogs went off as well (same for my daughter's
VW Golf). My current Yaris has the fogs on a column switch that is also mechanically linked to the headlight switch - turn off the headlights and the
fogs get pushed to off.
So any manufacturer that allows the driver to leave the fogs on needs a clip round its commercial ear...
[Edited on 20/10/12 by David Jenkins]
Ben_Copeland
posted on 20/10/12 at 07:30 PM |
They serve their purpose as indicators when necessary. That's it, that's what they are for. So should not be banned. Just because people
don't use them correctly doesn't mean they shouldn't ever be used or fitted. Whatever the point your trying to make its not what
striker was asking.
Ben
Roadster
striker-4age
posted on 20/10/12 at 07:31 PM |
going to try my luck at the mot as it has never had one.................and i am never going to be out in the fog
only time will tell
stevegough
posted on 20/10/12 at 07:42 PM |
only time will tell
Just realised you were asking about MOT, not the IVA test! Never mind, if you ever build one, now you know!
Quick googling, came across this....
15 POINT PRE MOT CHECKLIST
Learn more about looking after your car
1. LIGHTS
Just under twenty percent of MOT failures are caused by a dead bulb. Run through the list below to ensure you’ve checked all your bulbs. If you don’t
have anyone to help you check your bulbs, park up close to a wall or garage door. It's worth mentioning that some indicator and brake light
bulbs have a colour coating which starts to peel as they get old. As the colour peels off, the bulb shines white and is a test failure, even though
the bulb itself is working. Check the colours are correct at the same time as making sure they all work. Check all light fittings are secure and there
and no cracks or damage.
Headlights: Main beam and dipped
Sidelights: Front & rear
Indicators: Front, rear & side
Brake lights
Number plate lights (only on the rear plate!)
Reverse lights (not actually part of an MOT but worth checking)
Rear fog light (front fogs not checked)
Hazard lights (check seperately from indicators to make sure circuit works)
Luego Locost C20XE.
emlyno
posted on 20/10/12 at 07:54 PM |
If the car is later than 1st April 1980 then rear fog light (s) are a legal requirement.
If 2 are fitted they must be a matched pair.
The location of them in relation to the other rear lights is important.
Hope this helps.
striker-4age
posted on 20/10/12 at 08:02 PM |
so if the reg is from the donor car ??? pre 1980 ?
Ben_Copeland
posted on 21/10/12 at 07:03 AM |
No kitcar manufactured date. Nothing to do with donor.
Ben
Roadster
stevegough
posted on 21/10/12 at 07:13 AM |
Just to clarify Ben's line - my kit was finished in 2011, it was registered with an age - related plate - related to the donor Sierra.
So, its reg is K904AHG but it is classed as new in 2011 - its first MOT will fall due in 2014.
Bet you're really confused now!
On the other hand, the MOT is say, £54. You take it in and it fails because it has no foglight, you fit a fog, you take it back within 10 days I
think it is? - there's no retest fee. Problem solved.
Luego Locost C20XE.
loggyboy
posted on 21/10/12 at 07:38 AM |
Retests aren't always free usually they are only free if the necessary repairs are done by the garage and thecar doesn't leave the
premises.
Mistral Motorsport
snowy2
posted on 21/10/12 at 08:00 AM |
I wish i could say that...i drive chemical tankers and do 120,000km's a year at least and often get down into Norwich often and driving in fog
is one of the hassles i have to put up with.
My problem is with rear fog lights not fronts... Rear fog lights, even in very thick fog they are a problem....if you are driving in such thick
for you cannot see the road, stop and wait for it to clear. if you can see enough to proceed with care how does rear fog lights help? if some one
comes up behind you in the fog how does having fog lights help them? if they are driving to the conditions they will see you in plenty of time
regardless, if they are not and are driving too fast fog lights dont help them either....they are still idiots. once behind you your fogs will likely
be dazzling them and they will be bright enough that missing brakes lights coming on is a possibility.
I understand the law regarding them and the fitting and marking of them, i was just expressing an opinion about them
If we have to accept that they are necessary then it should be a requirement to turn them off when someone is behind you. (they have clearly seen you)
Ben_Copeland
posted on 21/10/12 at 09:08 AM |
So if the fog is so bad you can't see and have to stop. What stops people hitting you if you have no foglights? Even parked at the side of the
road etc. you'll still be a serious hazard.
I do agree people that use them when they shouldn't should be shot, but they are useful for identifying slower moving vehicles from a distance.
You shouldn't be getting close enough to the back of people in thick fog to be dazzled. I drive all over the country in all weather and in
different vehicles and I wouldn't be without fog lights even if I only use them couple times a year.
Ben
Roadster
stevegough
posted on 21/10/12 at 09:44 AM |
Well put that man!
Luego Locost C20XE.
