Relph
posted on 11/11/12 at 02:45 PM |
Hayabusa 2006 wiring diagram
Hi, has anyone got a wiring diagram showing the mods i need to do to it
i.e. What resistors and where and what wiring to remove.
Thanks.
daniel mason
posted on 11/11/12 at 07:01 PM |
there is a seller on ebay doing them.a3 size.
what ecu are you running as sbd do a superb wiring loom to suit mbe management. i got one and the quality is superb. but not cheap. its expandable
though and has can facility,full throttle shifts,launch etc
Relph
posted on 11/11/12 at 08:13 PM |
Hi mate, im running standard ecu with power commander for now. The wiring diagram on ebay is it a standard diagram or does it show whats got to be
modified ?
daniel mason
posted on 11/11/12 at 08:19 PM |
is your busa not turbod? what injectors are you running? the diagram is standard but will give you a good idea of what can be removed
Relph
posted on 11/11/12 at 08:31 PM |
No mate will have a standard busa in to begin with, untill ive got it all sorted and on the road.
I already have a standard diagram but i know you have to put afew resistors in to get it running correctly.
Duncan36
posted on 15/11/12 at 08:59 AM |
i have a diagram that shows what needs to be changed, it was also posted in the BEC section recently. It's on my ipad at home but i'll
post a link later
Relph
posted on 15/11/12 at 09:09 AM |
Cheers mate, im at a standstill at the minute without a modified wiring diagram.
Duncan36
posted on 15/11/12 at 09:16 AM |
Just found it, hope it's of use. http://www.team-moto.com/HayabusaWireHarness.jpg
Also if you look at this thread
http://www.locostbuilders.co.uk/forum/23/viewthread.php?tid=167254&page=2
SJL said he had an instruction manual for how to modify the loom.
good luck, i was just about to do the same and then sold my busa on saturday.
Duncan
Relph
posted on 24/11/12 at 09:40 AM |
Ive tried to contact SJL, but had no luck.
Has anyone else got the info on modifying the loom.
Thanks.
