beaver34
posted on 9/12/12 at 09:53 AM |
4 wire lambda
wiring in a 4 wire lambda into my omex
i have 2 white
1 grey
1 black
can any confirm what the colour do and where they go, its a ford sensor
thanks
posted on 9/12/12 at 10:19 AM |
If you go to http://www.gendan.co.uk/product_O24WIRE.html all is revealed.
beaver34
posted on 9/12/12 at 01:08 PM |
Thanks,
Any ideas on where the heater ones get wired is one an earth the other live ?
indykid
posted on 9/12/12 at 01:20 PM |
It's just a heater element so it doesn't matter which way round they go.
As long as one gets 12V, the other 0V you're sorted
ss1turbo
posted on 10/12/12 at 11:40 AM |
Theoretically, the heater should only be powered with the engine running, so often gets powered the same time as the fuel pump. Normally though, any
ignition live feed should be fine (whatever feeds the rest of the engine - ignition or EFi).
Long live RWD...
