Author: Subject: CORTINA COLUMN SWITCHES TO PREMIER LOOM DIAGRAM
zetec-phill
posted on 4/1/13 at 07:05 PM Reply With Quote
Hi, anyone got a wiring diagram, to wire a premier loom to cortina mk4 column switches...
big-vee-twin
posted on 4/1/13 at 09:02 PM Reply With Quote
Premier didn't do a diagram just written instructions which to be fair are straightforward.
Do you have a copy? I could send a copy to you if you u2u me your email.
http://www.triangleltd.com
SteveWallace
posted on 4/1/13 at 10:03 PM Reply With Quote
The following are diagrams that I did for the Premier Loom to Sierra switches (the colour codes marked 'P' are the Premier Loom colours, the ones marked 'S' are Sierra). If these are any help as a starting point, send me a U2U with your e-mail address and I'll send you the Powerpoint versions.
snowy2
posted on 5/1/13 at 08:04 AM Reply With Quote
there appears nothing wrong with the wiring diagrams above......but the classic mistake of using the output of the main beam relay to give the main beam warning lamp its feed. Fine, but you have a wire running the length of the car for no reason. It is much better to take the warning lamp feed directly from the switch that "triggers" the relay, then you only have about 12" of wire to be used.
sometimes you are the pigeon, most of the time the statue.
SteveWallace
posted on 5/1/13 at 09:58 AM Reply With Quote
You may well be right, but the Premier Loom is already wired up to take the feed from the output of the relay, so in my case it was easier to use what was there than to run a new, short, wire direct from the switch.
I guess that the other reason for not doing it the way thay you suggest is that if the relay fails, the headlights will not come on but you will still get the main beam warning light. The way that its wired means that there is nothing but wire between the warning light and the headlight bulb, so you can be fairly sure that the lights are actually on if the bulb on the dashboard is lit.
snowy2
posted on 6/1/13 at 08:52 AM Reply With Quote
to play devils advocate...
i am not sure that knowing that when the main beam warning light on the lights are working is all that useful. if you dont know the main beams are on (because its day light) then you dont need them.....if its dark you should be able to tell if they are working. besides the warning lamp working independent of the relay is useful for fault diagnostics, because if its lit the switch is fine so your looking at a relay fault.
I also didnt know that the premier loom was wired that way, but then i would never use their loom. all of my cars (kits and customs) have been wired using my own loom for which there is an article or link to one on this site.
it has occurred to me to do an addition to my article using a peg-board layout for a typical "7" style car, and using lucas wiring colours. however i am not convinced that doing that would encourage any more folks to give it a try. the fact is some folks like to build their cars and some like to assemble them. me i am a builder.
SteveWallace
posted on 6/1/13 at 07:05 PM Reply With Quote
This is my first build and I knew nothing when I started other that what I learnt years ago on my first car (a clapped out Fiesta).
I know a lot more now and if I ever get around to a second build (both SWMBO and daughter have their orders in..) then I quite fancy doing my own loom from scratch. Once you start looking at them a circuit at a time, they don't look that difficult. One of the reasons that the Premier Loom looks so complicated is that its wired for several different options and switch types.
