rdodger
posted on 11/1/13 at 07:48 PM |
Relay wiring
Evening all
Just a quick one
I have some relays in my donor loom (MX5) labeled COM, NO, COIL, COIL.
So easy enough but does it matter which coil goes to earth? When I put power to it quickly the relay clicked either way I did it.
So does it matter or will I have to test it properly?
gremlin1234
posted on 11/1/13 at 08:31 PM |
no - normal open
com - common
[nc] - normally closed
coils can /usually/ go either way, some can use ac too
big-vee-twin
posted on 11/1/13 at 08:35 PM |
The only time it makes a difference is if there is a diode across the coil, but they are usually indicated on the markings
As you have tried it both ways and it clicked it hasn't got a diode so yes either way is ok
http://www.triangleltd.com
omega 24 v6
coils are fine either way unless they have a diode across them for backward emf.
rdodger
posted on 11/1/13 at 08:46 PM |
Thanks guys.
