Author: Subject: R1 5vy exup wiring plug wanted
Hadders
posted on 19/1/13 at 09:06 PM Reply With Quote
I have the exup valve but not the plug to connect it to the wiring. I know you can fool the ecu or just leave it off, but I reckon I might as well wire it in anyway. Does anyone have the plug and / or a can post a photo of which wire goes where in the plug? Guess I could get a plug from vwp or similar if necessary.
Many thanks
Coopz
posted on 20/1/13 at 08:39 AM Reply With Quote
I might have one in the garage, I'll be in there later will have a look for you. If not u2u me your email and I will send a photo.
Cheers Toby
renetom
posted on 20/1/13 at 10:03 AM Reply With Quote
Exup
Hi
Ours is a 2001 engine , we tried the exup fooling boxes which did not work
Then fitted exup motor all problems cured , removed the pulley & cut the shaft
Neat & light.
As we didnt have a plug either so We soldered & heatshrunk the wires
Better connection than the plug & anyway you would have to solder the plug on.
this is the wiring for ours, check to see if its the same as yours.
Good luck
René
[Edited on 20/1/13 by renetom]
Hadders
posted on 20/1/13 at 04:04 PM Reply With Quote
Thanks guys that's great. I'll get back out to the garage and check your diagram Rene and let you know Toby if I need to get a plug. Thanks again.
Hadders
renetom
posted on 20/1/13 at 05:40 PM Reply With Quote
diagram
Hi
As said the diagram is from a 2001 Yam R1 manual.
I also have a 2004 yam R1 manual both are in PDF format
If you want a copy of either send me UTU with your email
& I'll send you a copy.
René
Hadders
posted on 21/1/13 at 07:04 PM Reply With Quote
Toby. You have U2U.
Ben
