Author: Subject: starter wiring
beaver34
posted on 5/2/13 at 07:29 AM Reply With Quote
starter wiring
need some info on wiring in my car,
should the starter motor connect direct to the battery?
it allways has been since i got the car but was unsure if this is normal or if it needs to be within the cut off circuit
thanks
ReMan
posted on 5/2/13 at 08:17 AM Reply With Quote
Normally straight to battery
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
renetom
posted on 5/2/13 at 08:42 AM Reply With Quote
+1 Battery
The solenoid should be within the cut off circuit
snowy2
posted on 5/2/13 at 07:37 PM Reply With Quote
depends what type of starter you have.....
inertia (not very common these days but are on Crossflow engines)
Pre -engage starters....you can tell these as the solenoid are on top of the starter motor, in which case the starter wire (the thick one) goes direct to the battery +ve/
sometimes you are the pigeon, most of the time the statue.
