olimarler
| posted on 16/2/13 at 09:35 AM |
Bike battery
Is there any issues with running a car battery instead of a bike battery?
I understand they will prob be heavier etc but will it cause any issues with the charging etc.
Cheers guys
Oli
loggyboy
| posted on 16/2/13 at 09:40 AM |
A car battery in BEC will be fine.
Mistral Motorsport
mark chandler
| posted on 16/2/13 at 09:46 AM |
Make sure it's a small one !
Bike generator/alternators are not as strong as car ones so you can have issues with burning out the field coils/regulator packs.
Some are weaker than others, 893/918 blade engines for instance.
Regards Mark
olimarler
| posted on 16/2/13 at 10:44 AM |
It's a 1990 Honda cbr 1000 f .
Any recommendations what I could you?
sdh2903
| posted on 16/2/13 at 10:53 AM |
Any reason why you would want one? are you running electric reverse?
Otherwise I can't see why you would need a bigger/heavier/expensive car battery?
40inches
| posted on 16/2/13 at 10:58 AM |
I have a Varta B34 battery fitted, smallish, under £50 and 330cca.
renetom
| posted on 16/2/13 at 11:06 AM |
battery
Hi
Our R1 engine has a magneto so not a problem, car or bike.
But as previously stated why would you want one ?
Are you going to fit an electric reverse ?
Whatever you decide good luck.
René
| posted on 16/2/13 at 11:12 AM |
I used a red top for a Buell in my zetec CEC. No problems what so ever..
olimarler
| posted on 16/2/13 at 12:28 PM |
Just curious firstly!
But I don't get to drive car often and the battery from the bike doesn't seem to last long and hold its charge!
It is a new battery
Oli
| posted on 16/2/13 at 12:29 PM |
Get a trickle charger or an optimiser.
even just one of them little solar panels stuck on the winda will do it for ya..
[Edited on 16/2/13 by coozer]
olimarler
| posted on 16/2/13 at 12:40 PM |
Trickle charger I would like but no power source near car!
The solar panel is not a bad idea!
