T66
| posted on 22/2/13 at 08:32 AM |
Premier Wiring - Thank You
Just taken delivery of the Fiat loom, purpose made to my specification, and all the way from Spain without a problem @ £190
I could spend £120 on wire and the next 12 months scratching my head. ...
Alan - Thank you....
http://www.premierwiring.co.uk/
imp paul
| posted on 22/2/13 at 03:51 PM |
owww sounds good ivo is this just a lighting loom or does it have the bike engine loom in there ?. as i have the zx12r harness to get sorted eg
engine loom and lighting loom i dred the day lol. hope its going well for you mate as im having night mares with mine
T66
| posted on 22/2/13 at 05:56 PM |
Hello Paul,
Its the full loom, minus the engine loom and whatever I forgot to get included when Alan put it together...
My MIG is playing up, so is in bits, and the garage is -15c , and my biggest nightmare is I havent a clue what im doing lol, but apart from that its
going slowly.
Whats your bother ?
[Edited on 22/2/13 by T66]
imp paul
| posted on 22/2/13 at 06:08 PM |
hay up mate loom looks nice and its good that your not sure what your doing lol . its the way forward hehe as for my car problems its my new home
made false floor. as it meets my imp floor there needs to be some more strenth.and the front cage legs could do with tieing in to the bulk head. but i
need cds cage tube bending for the job and i do not have that type of skill just getting fed up of it feels like a waste of money mate.
  this is my home made bolt in floor so far
  trying to work out a way to tie in to front end as it needs more strenth
[Edited on 22/2/13 by imp paul]
T66
| posted on 22/2/13 at 06:36 PM |
Stick with it Paul - We all get peed off with the garage contents.
On mine the shell is supported by decent tabs welded to the top edge of the horizontal dash bar, two tabs welded to the cage on the top screen
horizontal. A flange welded to the main roll hoop vertical sections. I need to weld 4 tabs onto the sill bars, 2 either side.
Under the rear 126 parcel shelf there are 2 plates tied into the chassis, the back 1/4s were flopping about , so they now have 16mm square section
holding them both steady.
are you sure you need CDS bent ? Pot up some pictures here, and lets get it sorted out !
There will be a solution here for sure....
imp paul
| posted on 22/2/13 at 07:01 PM |
cheers mate its just not going all that well. but the above pics are my new floor and it bolts in and out its not a weld in floor so the car can come
apart if needs be here is a new pic with my idea of fitting some more cage tube but it would need to be bent to suit the shape of the car if you know
what i mean
  just a few thorts to maybe inprove it
T66
| posted on 22/2/13 at 07:30 PM |
My car is a complete rolling chassis, it just happens to have a Fiat 126 shell on it, not a stressed part of the car for suspension etc.
What suspension front/back setup does yours have ? Does it still bolt to the original Imp shell ? So needs holding up ?
imp paul
| posted on 22/2/13 at 08:11 PM |
ivon have a look at my photo album this mite help you see how it works. its a full imp with the floor cut out up to the front as in pics above and
the space frame bolts to my false floor and it goes in to the bulk head in to a front space frame
