Author: Subject: Sierra to Scorpio stalk
belgian2b
posted on 2/3/13 at 03:55 PM Reply With Quote
Hello,
i am on my way to finish the Tiger Cat i started one year ago.
the loom i received from Tiger was designed for a Sierra donor.
I will use the indicator stalk for indicator , highbeam and hazard.
So i build it all with a sierra stalk , and now that i know that everything works, i want to change to a Scorpio/granada stalk( my steering column is from a scorpio.
So, does any of you have the wiring diagrams for both stalks ?
On the Scorpio, the hazard relay is integrated to the stalk, when it is separate on the sierra , but this is not a problem.
I just want to connect the wires from the Tiger loom to the scorpio stalk.
you will find here the picture of the stalks ( first is sierra, second is scorpio)
http://locostbuilders.co.uk/upload/P1050465.JPG
http://locostbuilders.co.uk/upload/P1050464.JPG
Gerardo
[Edited on 2/3/13 by belgian2b]
pekwah1
posted on 2/3/13 at 04:15 PM Reply With Quote
I've just changed from sierra to escort which was a piece of p*ss!
Try googling the pinouts.
Otherwise both the stalks should have numbers identifying each wire usually where the connector block fits in.
Just compare these and swap each over respectively!
belgian2b
posted on 2/3/13 at 05:24 PM Reply With Quote
Hello,
it was easy to find the pinout of the sierra, btu i can't fin done for the granada/scorpio.
I can't look at the pin number because the granada/scorpio has no number on the red connector
So, next job is try to find the Granda/scoprio pinout !!
Gerardo
pekwah1
posted on 2/3/13 at 06:02 PM Reply With Quote
Have you looked at where the connector actually plugs into on the stalk itself? There should be moulded letter either next to or inside the connector bit next to the pins.
