wylliezx9r
posted on 18/3/13 at 08:31 PM |
Exhaust manifold flange S2000 F20C (can anyone make one)
As above, I'm after an s2000 exhaust manifold flange, does anybody know where I can source or get one made in the UK ?
Thanks in advance
George Best
mark chandler
posted on 18/3/13 at 08:59 PM |
Make an accurate drawing of what you want or a plywood template then give andyw7de a call on here, if he is still able to cut I'm sure he will
be able to help you out.
Andy has cut a couple of things for me in the past, really excellent work.
Failing that get a bit of strip steel wide and thick enough, you should be able to get an off cut, the stitch drill hole saws and a Dremel will sort
you out for a couple of hours effort. Sometimes thinking about something like this takes longer than just doing it, 4 big holes and a handful of small
ones really
Regards Mark
SeanStone
posted on 18/3/13 at 10:06 PM |
I've got an s2000 manifold/downpipe if you want to buy it and chop that up
FASTdan
posted on 19/3/13 at 10:38 AM |
If you send me a gasket I can copy and get cut. U2U for more info
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
pwl
posted on 19/3/13 at 09:16 PM |
They are on ebay.com
Honda S2000 Custom Exhaust Header Weld Flange F20C Durable Paintable Mild Steel | eBay
