Author: Subject: Poor Spark
OrangeJuiced
posted on 20/4/13 at 04:26 PM Reply With Quote
Poor Spark
I currently have a very weak spark being generated by the coil. The Coil and ignition module are brand new. It’s a pinto running a standard ford distributor.
It has been running rough when hot for the last couple of trips hence the new module and coil. Currently it won’t even start. Any ideas or helpful suggestions would be much appreciated?
Cheers.
Ad
blakep82
posted on 20/4/13 at 06:35 PM Reply With Quote
New plugs?
MAte had similar problem on his bike. Said to him to look at coil packs as it was only a problem when hot and riding, not when standing still. He insisted on stripping the carbs, which unsurprisingly made no difference. Plugs were humped
[Edited on 20/4/13 by blakep82]
________________________
OrangeJuiced
posted on 20/4/13 at 06:56 PM Reply With Quote
Plugs and leads are 100 miles old so should be fine.
I think it's before the ht leads as its the sparks from the coil are weak.
Smoking Frog
posted on 20/4/13 at 07:03 PM Reply With Quote
Do you have a ballast resistor fitted to the coil? Maybe faulty condenser. Other than poor connections I can't think of anything else.
Eddie
[Edited on 20/4/13 by Smoking Frog]
umgrybab
posted on 20/4/13 at 07:44 PM Reply With Quote
Eddie
I was going to suggest this but was unsure if the ignition module did this portion of it, or just the timing. On a straight forward points/distributor set up, I'd say it was the condensor.
