J222jra
posted on 16/5/13 at 08:28 AM |
Wiring motorbike fuel pump...
Hi guys just wondering how you guys have gone about wiring motorbike fuel pumps? Any special requirements I should know about?
Thanks in advance.
James
posted on 16/5/13 at 09:11 AM |
2 wires 12v and earth....
40inches
posted on 16/5/13 at 09:44 AM |
On bikes the pump is run through a relay, but this may only be an interlock, the pump only runs when the starter button is pressed and the engine is
running, not when the ignition is switched on.
But as coozer suggests you could wire it through the ignition switch.
posted on 16/5/13 at 09:47 AM |
Yep, sorry, switched 12v...
