Benzine
posted on 5/7/13 at 09:08 AM |
Sorting out a tachometer
What's a locost/scrapyard friendly way of rigging up a tachometer? I can't use the one that the donor engine (XUD) used as the flywheel
(HDI) has a different number of teeth and the gearbox (Pilot) doesn't have a place to mount a sensor.
I've heard of running them off the alternator but that looks a bit complicated. Some kind of sensor on the crank pulley?
deezee
posted on 5/7/13 at 11:13 AM |
Can you take it off your ECU?
[Edited on 5/7/13 by deezee]
Ben_Copeland
posted on 5/7/13 at 11:23 AM |
Coil? Coil pack? Ecu? There many ways
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
posted on 5/7/13 at 12:24 PM |
An old Peugeot turbo diesel has none of these things.
You can buy a
converter to adapt
a petrol engine tacho to a diesel as long as you alternator has the W terminal (or you are happy taking it apart and connecting a wire to the
rectifier to get a single phase output).
You could ecven build a diesel tachometer from scratch.
[Edited on 5/7/13 by MikeRJ]
Benzine
posted on 5/7/13 at 09:17 PM |
Thanks for those links, Mike. I've remembered that I have a spare alternator in the garage that's the same as the one I'm using in
my MK so i'll have a look inside that and see if it's suitable
