Author: Subject: Alternator help
ChrisLeary
posted on 29/7/13 at 12:55 PM Reply With Quote
Alternator help
Afternoon all,
I've done lots of searching and found the following thread which uses the same alternator as I've got from a micra.
http://www.locostbuilders.co.uk/viewthread.php?tid=39765
So now I know what the pins are, but how do they actually connect into the loom? Is the battery sense just connected to a switched live from the ignition?
I suppose it would be easier to ask if anyone could do me a quick sketch of the circuits I need to make for the battery sense and charge light? Please?
Please forgive my lack of knowledge, electronics really isn't my thing.
Thanks in advance,
Chris
Don't force it! Get a bigger hammer...
ChrisLeary
posted on 29/7/13 at 04:22 PM Reply With Quote
This the circuit diagram I've managed to come up with some how, although I'm not entirely sure it's correct and more importantly... will work!
Alternator wiring
Alternator wiring
Thanks again,
Chris
big_wasa
posted on 29/7/13 at 04:50 PM Reply With Quote
I would be running the sense wire as a switched live and not permanent live.
ChrisLeary
posted on 29/7/13 at 05:15 PM Reply With Quote
Thank you for that, anything else you'd change or does the rest look ok?
Thanks again,
Chris
ChrisLeary
posted on 30/7/13 at 03:34 PM Reply With Quote
Anyone? Any other suggestions or is this going to work?
Like I said originally, my electronic system knowledge isn't great so some help really would be appreciated.
Thanks again,
Chris
