daveb666
posted on 20/8/13 at 10:24 AM |
2 Wire / 3 Wire Crank Sensor
My zetec has a 2 wire crank sensor. The SBD loom I have purchased has a socket/wiring for a 3-wire crank sensor installed.
Should/Can I:
1 - Chop off the 3 pin plug on the SBD loom, fit a 2pin plug (if so which wires?) and use existing sensor
2 - Replace my 2 pin crank sensor with a 3 pin?
Ben_Copeland
posted on 20/8/13 at 11:42 AM |
You might find the Ecu needs a 3 wire crank signal. I'm pretty sure megasquirt does.
What's the recommended crank sensor for yours?
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
daveb666
posted on 20/8/13 at 11:49 AM |
God knows ?! How do I find out?
XE ones are 3 wire.
big_wasa
posted on 20/8/13 at 12:00 PM |
First things first. What engine was the ecu configured for ?
I've not seen a duratec or newer but older Ford's are a two pin Vr sensor. A lot of Vag engines use a three pin sensor. Some are a vr
sensor with an extra shield and some use a Hall affect sensor. These are power earth and sense.
If yours is configured for a vr sensor then you can just use the two you need. If it's configured for Hall affect then you will need to see if
it can be changed.
Some ecu's use a seperate wire and you will just need to rewire, some use jumpers in the ecu and others will be done by software.
You won't get a three pin sensor to fit the block and read the fly wheel. You could use a Hall affect sensor on a trigger wheel but if the ecu
had been configured for any thing elts other than a Ford it won't be set up for a 36-1 trigger patten.
daveb666
posted on 20/8/13 at 12:06 PM |
ECU was originally from a Ford CVH running bike TBs.
MBE does allow you to change the relevant trigger wheel settings within the system itself, as I remember that from my vauxhall days.
big_wasa
posted on 20/8/13 at 12:07 PM |
Its a zetec, so that's a two pin vr sensor. If used with something like megasquirt then you would have an extra shield that runs the full length
from ecu to sensor but is just terminated at the ecu to earth to stop interference.
If the ecu was for an xe ? you will still need to change the trigger pattern.
big_wasa
posted on 20/8/13 at 12:10 PM |
If it was an early cvh then it could be set up for a hall affect sensor in a distributor or latter ones had a vr sensor on a trigger wheel on the
front pulley.
daveb666
posted on 20/8/13 at 12:34 PM |
so my first attempt is going to be to reconnect the 2 sensor wires, ignore the earth and try it with my own sensor?
big_wasa
posted on 20/8/13 at 01:28 PM |
Is one of the three wires yellow ?
daveb666
posted on 20/8/13 at 01:43 PM |
Haven't peeled back the shroud on the loom, I'll take a look tonight
big_wasa
posted on 20/8/13 at 03:30 PM |
I really want just hack bits and try. See what it was set up for and go from there. If it cant be changed to vr it will still be saleable as it is.
daveb666
posted on 20/8/13 at 03:34 PM |
Too late for that as I replaced all the injector plugs this weekend!
big-vee-twin
posted on 20/8/13 at 05:43 PM |
The Duratec crank sensor is two wires, megasquirt uses two wires
http://www.triangleltd.com
Hector.Brocklebank
posted on 20/8/13 at 08:45 PM |
if its an MBE ecu then it should have details & "notes" on the sticker on the ECU
for example
Model of ECU
9A4B
Firmware
BOM Code: 1.8
Serial number
000*****
Then in the Notes section on the sticker you should have
Supplier = SBD
Ignition config = HSD
(in this case for using external ignitors, this is a hardware configuration and not user adjustable in the software)
Crank Sensor =H/E Crank
(in this case a Hall effect crank sensor
to clarify
2 wire sensors are usually classed as dumb variable reluctor sensors (hence VR sensor)
But they can have three wires on their plug the "third" actually being used in a shielding capacity and not connected to anything at the
sensor end.
3 wire sensors are usually classed Hall effect digital sensors
with the wiring usually being
5v analog
0v signal
analog ground
Its might not be the best idea to just hack a plug off willy nilly, call to Steve @ SBD tomorrow & it will yield you the definitive answer as to
wheather you can use a VR or H/E sensor in conjunction with your setup
But look Here &
Here
And navigate to the wiring section for more info, anything else is just wild speculation and usually results in tears
[Edited on 20/8/2013 by Hector.Brocklebank]
Some people can never handle the truth and always try to shoot the messenger instead of taking an honest look in the mirror (its always easier to
blame another than to face reality), but secretly they wish they could grow a pair and be the messenger !!!
