Author: Subject: Fog light for MOT question ?
steve m
posted on 22/8/13 at 06:45 PM Reply With Quote
Hi all
My 7 does require a fog light for the MOT, as per the orig spec of the car, as I am pre SVA/IVA etc
But for the MOT does the said light have to be a "fog light" or could I switch it to the 3rd brake light which is a strip led, ?
Ive read an oldish MOT tester guide, and it doesn't say that it has to be a "emarked or what ever light"
pic of 3rd light under the no plate, but I have taken the fog light off for the moment
mookaloid
posted on 22/8/13 at 07:03 PM Reply With Quote
I don't know - but I like it
chrism
posted on 22/8/13 at 07:07 PM Reply With Quote
I think it needs to be located on the offside of the vehicle for the MOT if there is only one, so being in the middle probably wouldnt pass, but it should be bright enough.
UPDATE: Never mind looks like central is allowed.
http://www.motuk.co.uk/manual_130.htm
[Edited on 22/8/13 by chrism]
A little hard work never killed anyone, but why take the risk!
coyoteboy
posted on 22/8/13 at 07:11 PM Reply With Quote
I've been running my fog lights as additional brake lights on the tin top for years (standard lights are a bit pants and I had a few folk get very close at dusk). But I'm fairly sure the fog light has to have separate wiring, be independent and have a tell-tale.
chrism
posted on 22/8/13 at 07:14 PM Reply With Quote
Im guessing he already has that and just wanted to get rid of the separate fog light and use the 3rd brake light instead, easy enough just to wire up to the existing fog wires.
bigfoot4616
posted on 22/8/13 at 07:40 PM Reply With Quote
what year did the foglight requirement come in? mines been through its last 4 mot's without one although it is on a Q plate.
just read the above link, 1980
[Edited on 22/8/13 by bigfoot4616]
steve m
posted on 22/8/13 at 07:43 PM Reply With Quote
I have a switch that changes the strip light from a 3rd brake light to the fog light, and it does only come on with ign on, and lights selected, plus has its own illuminated light on the dash
My car is a 1979, and DOES have to have a fog fitted
bigfoot4616
posted on 22/8/13 at 07:52 PM Reply With Quote
if its 1979 according to that link it doesn't, it states 1st april 1980 and later needing one.
steve m
posted on 22/8/13 at 07:59 PM Reply With Quote
I believe, that if it was fitted as oe, even pre 1980 then it had to work,
I could argue it, as my "tester" is ok
steve m
posted on 22/8/13 at 08:04 PM Reply With Quote
OOPs
My car was first registered on 04 08 1980 so DOES req one
bigfoot4616
posted on 22/8/13 at 08:44 PM Reply With Quote
i did think W was 80/81 but it is a long time since i've had a car that age so couldn't remember for sure.
is it not easier to just replace the other fog light and remove it again after or has the wiring been removed as well?
that's what i do with my number plate light, made up a bracket that sticks to the back of the number plate.
steve m
posted on 22/8/13 at 08:51 PM Reply With Quote
Your so right, but I cant be arsed!!
dhutch
posted on 23/8/13 at 09:42 AM Reply With Quote
I don't know what the regs are, but I have to admit, as long as it looks sensible I expect you could get most things thought an MOT, such as using a racing rain light as a fog light.
That said, I think using a high level LED brake as a fog light is a poor idea, and would certainly not be overly happy with it on my car, or as am MOT tester, as its confusing and blatant miss use of parts.
Although I am also a massive advocate of having a bright foglight, and am very aware that should the weather turn bad unlike a modern tintop where there a bit optional, on the kit you really cant be seen if you don't use the fog light to the extent that if im on the motorway often pull of at the next exit to check the bulbs still working, so do mean to swap it out for the LED fog light I have bought (with matching rev light).
Daniel
loggyboy
posted on 23/8/13 at 10:21 AM Reply With Quote
Brake lights are the same Wattage as FOG, but the lens pattern is very dififferent.
There must be a fog light on the market that has a similar shape to a 3rd brake light you could use.
Mistral Motorsport
