carlknight1982
posted on 30/8/13 at 07:29 PM |
Cant communicate with Megajolt
I cant get my pc to talk to my megajolt, ive tried several cables and several usb to serial adapters its just not having it,
the reason i want to look at it is my Acewell dash is reading my RPM about 1200 RPM higher than it is, and occasionally 200rpm without the engine
running
Ideas guys
Logic will get you from a A to B
Imagination will take you everywhere.
steve m
posted on 30/8/13 at 08:21 PM |
I am sure Pekwah1 had the same problem, but not sure how he fixed it, (if he did)
Your not set up for 6 cylinders or something like that are you?
dave_424
posted on 30/8/13 at 08:51 PM |
What cables have you tried?
Did any of the cables come with a driver CD or are you using other drivers from the web?
Dave
austin man
posted on 30/8/13 at 09:35 PM |
I think you have to configure the USB to be port 1 if you are using a usb to serial
carlknight1982
posted on 30/8/13 at 09:38 PM |
Ive done that its just not communicating
Andybarbet
posted on 31/8/13 at 12:12 AM |
I have an old laptop with a serial port - been keeping it for when I get my megasquirt installed, your welcome to borrow it if you run out of ideas
with usb convertors.
I will try & plug it in tomorrow to make sure it still works.
snapper
posted on 31/8/13 at 04:47 AM |
Only problem I have ever had is with COM port
Either its floating and changes ever time or is using a COM port number higher than 10
I eat to survive
I drink to forget
