Author: Subject: Ramdonly clicking relay?
Xtreme Kermit
posted on 31/8/13 at 07:31 PM Reply With Quote
Here's one for you electrical gurus...
Whilst driving along my indicator relay clicks randomly - when the wipers are used it ticks and clicks like its on speed...
And yet use the indicators and it calms right down and acts normally.
The indicators only light when in use...
Pull the indicator relay and everything is normal - with the exception that the indicators don't work
In the words of the song "What's going on?"
adithorp
posted on 31/8/13 at 07:40 PM Reply With Quote
Check the earths for the wipers, indicators and relays. Sounds like one of then is dodgy and it's back feeding via the flasher relay to get to earth.
http://jpsc.org.uk/forum/
Xtreme Kermit
posted on 31/8/13 at 08:04 PM Reply With Quote
Good thought, I was thinking of replacing the relay and seeing if that sorted it, but a dodgy earth sounds like a definite possibility.
It's a bugger though as that's a scuttle off job on the Xtreme as all the dashboard earth points are sandwiched in there.
Jon Ison
posted on 31/8/13 at 11:39 PM Reply With Quote
Place a good "tempoary" earth into the circuit, if it cures it make it permanent and cut the dodgy ones out without moving the scuttle. KISS.
Xtreme Kermit
posted on 1/9/13 at 02:52 PM Reply With Quote
That's a good idea Jon, but I don't know which circuit is faulty...
On the Xtreme, the fuse and relay panels are the only part of the electrics that are accessible without removing the scuttle.
Oh well - another job for the list...
