beaver34
posted on 25/9/13 at 06:20 PM |
dash two gear indication
hi,
my dash two gear indication is not working correctly, just wanted to pick the brains of someone that has got it working correctly
its a h pattern box, the issue i have is it flick between 4th and 5th gear when in 4th gear.
1 to third seem to work fine.
any one had this issue?
i had the diff out the heck the ratio and i think i have the correct box ratio's but going to recheck it all
thanks
jeffw
posted on 25/9/13 at 07:25 PM |
Dash2 only works it out from road speed and revs. You need to put the correct figures in to get the right gear out.....
beaver34
posted on 25/9/13 at 09:03 PM |
Thanks for those wise words
jeffw
posted on 26/9/13 at 05:35 AM |
I wasn't trying to be annoying but I've had the same issue in the past. The calculated figures have to be correct otherwise you will have
this issue.
