Author: Subject: Zetec engines
JimM
posted on 2/10/13 at 12:50 PM Reply With Quote
Zetec engines
What are the quoted BHP figures for each for the Zetec engines ...
Silvertop 2L
Blacktop 2L
ST170 2L
all above in standard form and new from Ford ....
loggyboy
posted on 2/10/13 at 01:06 PM Reply With Quote
Silvertop
Eng code NGA - 132 PS @ 6000 180 Nm @ 4000 (Mondeo 2.0 To 05/98) (about 130bhp)
Blacktop
NGB/NGC - 130 PS @ 6000 180 Nm @ 4000 (Mondeo 2.0 05/98 On) (about 128bhp)
EBBC/EBBD/EDBA/EDBB 125 PS @ 6000 180 Nm @ 4000 (Cougar 2.0) (about 122bhp)
EDDA To EDDG 135 PS @ 6000 180 Nm @ 4000 (Focus 2.0) (about 133bhp)
ST170
(badged as duratec) but zetec variation 172 PS (about 170bhp)
Mistral Motorsport
wombat
posted on 2/10/13 at 01:29 PM Reply With Quote
ooh looks like I managed to get it right for a change !
May 98 Silvertop for 90 quid with <70k on the clock.
posted on 2/10/13 at 02:25 PM Reply With Quote
Thats the best option, bit of head work and some cams can = 200bhp.
JimM
posted on 2/10/13 at 03:13 PM Reply With Quote
Ok,
So a swap to the ST engine will yield ~ 35 BHP without any headwork or cams?
loggyboy
posted on 2/10/13 at 03:15 PM Reply With Quote
You will need a way to control the VVT.
Mistral Motorsport
JimM
posted on 2/10/13 at 04:49 PM Reply With Quote
Reading various posts on this topic ...
Option 1 is the replacement kit ... need a certain level of mechanical skills which i don't have.
Option 2 is the switch in at defined rev level ... I can work this one.
I also have the Megajolt system so option 2 is the easiest way.
This should still give the 35 odd BHP increase - with option to fit a kit at later date.
Is this a correct assumption?
big_wasa
posted on 2/10/13 at 04:57 PM Reply With Quote
You missed the best option of using the oem ecu
JimM
posted on 2/10/13 at 05:15 PM Reply With Quote
Cost too much ....
looking for best option to get more power as cheap as possible.
From what i can see, its a straight swap for the ST170 and when funds are available get the head done.
mcerd1
posted on 2/10/13 at 11:14 PM Reply With Quote
the problem with the ST170 is you need to deal with the VVT system
what ECU are you planning to use ?
me!
posted on 3/10/13 at 06:16 AM Reply With Quote
Originally posted by JimM
Cost too much ....
I suspect if Big Wasa can work his magic it may be the cheapest option for 170 horses and a big dollop of torque. You would probably have to use the OEM manifold though which is a bit of a lump. Having said that I don't think the delete kits are too expensive and you could probably give a locoster a few quid to fit it- the delete kit seems to get good reports when done.
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
Building: Run 2 ltr Black Top in single seater race car.
posted on 3/10/13 at 11:59 AM Reply With Quote
Didn't I read somewhere that fitting (2) two exhaust cams into a 2 litre black top gave a useful increase in power.....
JimM
posted on 3/10/13 at 12:54 PM Reply With Quote
Current setup is Blacktop 2Ltr Zetec with BoggBros manifold and R1 bike carbs.
With the Megajolt system I can program a switch for say 3000 RPM.
My non technical logic says the ST170 engine swap would give increased power (upto 170?) and more grunt torque over the current setup.
At a later date, other options to improve the Zetec (Duratec ST170) could be reviewed to get around 200BHP.
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
posted on 3/10/13 at 01:19 PM Reply With Quote
My current set up Black Top with R1 carb's on DanST manifold and Megajolt 160bhp @ 6500 afr 12.8.....
JimM
posted on 3/10/13 at 02:06 PM Reply With Quote
Now this is where i get confused - easily done ...
How does the Blacktop go from ~135 bhp to 160 BHP.
Does this mean the ST170 BHP will become ~ 200BHP.
mcerd1
posted on 3/10/13 at 02:31 PM Reply With Quote
^^ the short answer is 'No'
would you plan to run the ST170 motor on your current carbs ?
I doubt it would give you the 170 in that case - at least not with out a bit of work
also if you keep the same carb's you've got now they aren't going to be able to give you much more power than the bike they came from - so you may need bigger ones if your looking for big power (but this could cost you some low rev drivability)
a carb'd R1 is rated at 150 bhp, bogg bros told me they reconned they are good for ~160bhp+, but to go much beyond that you'd need bigger....
the engine is only going to give as much power as its weakest link can give
the std. ford 2.0 blacktop is found in family cars - so ultimate performance in not the priority
so by fitting some less restrictive intakes (i.e. carb's from a superbike that %100 about performance)
a less restrictive exhaust and some lumpy cams you can get a big power boost
but it'll cost you fuel economy and refinement
but the ST170 engine is trying to be two engines at once:
one uses a mild cam setting and is tuned for quietly running down to the shops
the other uses more aggressive cam timing and mapping to give you some extra performance
it changes over between the two if you drive/rev it hard (can't remember what the actual trigger is on the ST170)
the ST170 is meant to have a few other upgrades like a better ports in the head etc... which are worth a few BHP over the std. 2.0
and using a VCT delete kit lets you manually fix the cam positions at whatever timing suits you best (i.e. simplifies the whole setup)
[Edited on 3/10/2013 by mcerd1]
airforceone
posted on 3/10/13 at 03:40 PM Reply With Quote
2.0 Litre Zetec Blacktop tweaks
You have to remember that these BHP figures are usually Flywheel BHP, the wheel BHP is usually 15-20% less.
The zetec 2.0 does state 135bhp, so to get a reasonable increase Throttle Bodies are the cheapest option for the biggest
gains. I have Hayabusa TB's with an OMEX 600 ECU on my 2.0 blacktop and now have 168BHP (Flywheel).
I'm now going for a Stage 3 head with some race cams and a decat so should expect to see 210BHP. Reason I know this is that
the centre doing the work have just done the same on another zetec.
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
posted on 3/10/13 at 04:24 PM Reply With Quote
My figures are at the back wheels/ rolling road figures....
posted on 3/10/13 at 04:35 PM Reply With Quote
My St170 gave 166bhp with bike carbs (badly out of tune btw). Then I moved over to injection using GSXR TB's on the front plastic ST manifold. That gave 178..
My next upgrade was to junk all that, go back to a 2L Silvertop and slap a turbo on it for 350bhp...
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
posted on 3/10/13 at 05:00 PM Reply With Quote
Bugger.................
JimM
posted on 3/10/13 at 06:44 PM Reply With Quote
Nice one Coozer ...
so a simple engine swap from my current 135 BHP setup should yield ~ 170BHP without the need for throttle bodies and expensive CPU.
I Like it
