spoonana
posted on 14/11/13 at 08:14 PM |
HT Leads
Hi all
Has anyone any suggestion for my Tiger Cat E1
I have a 2.0l Pinto lump and I have a problem with the HT leads I bought for it
The Lead between the distributor and coil is about 30cm too short
Can anyone advise me of the relevant set I need to buy
Oh and anyone know the Spark plug clearances off their head
Many thanks
posted on 15/11/13 at 01:16 PM |
The ignition coil on kit cars is rarely mounted where it was original in the donor car, so no-one can tell you which set you need.
You can get a set custom made for a reasonable cost e.g.
here or you may be able to
find a motor factors that still sell individual HT leads; most of them used to do this, but since modern cars don't use HT leads not so many do
now.
r1_pete
posted on 15/11/13 at 01:57 PM |
VWP have everything you need to make your own, or pre made to length
Link
spoonana
posted on 15/11/13 at 02:31 PM |
HT Leads
Cheers Guys
Trollyjack
posted on 15/11/13 at 02:53 PM |
Move your coil closer
TrollyJack
baz-R
posted on 15/11/13 at 03:33 PM |
you can just take the coil lead to a autofactors and just ask for one the correct length
Not Anumber
posted on 15/11/13 at 04:48 PM |
Spark plug gap 0.7 to 0.8mm if using conventional ignition. 1.0 mm if using a Megagolt or similar distributorless ignition
spoonana
posted on 24/11/13 at 03:30 PM |
HT Leads
Ha those awfully nice chaps at Tiger said move the coil too.
Gonna get a longer one ordered
thanks
