John P
posted on 11/1/14 at 05:59 PM |
Is it Possible to use later Donor Instruments?
Just thinking about instruments and, as I’m trying to do things at the lowest possible cost, was looking into the possibility of using donor
instruments, possibly from a later vehicle.
I’m using Megajolt ignition so presumably should be able to pick up a suitable signal for the tacho from either this or the EDIS module but my MT75
gearbox has a cable output so I assume I’d have a problem using most later instruments where the speedo is electronic and (I think) probably needs the
original ECU to work.
Has anyone used donor instruments successfully and if so do you have any photos?
John.
posted on 11/1/14 at 06:35 PM |
John.
On most late model cars all the instruments are ECU driven rather than by values from the sensors.
[Edited on 11/1/14 by britishtrident]
deezee
posted on 11/1/14 at 06:37 PM |
I used Sierra instruments. First tacho had loads of problems as the original donor was using flyback off the coil and despite following the twin
diode plans on Megajolt website, it was intermittent at best. I swapped over the module in the instrument panel, for a later model tacho and this
works fine, running off the Megajolt.
My speedo is cable driven, but if you move to an electronic one, just get the electronic sensor off the gearbox to go with it.
