jimmyd
posted on 1/2/14 at 11:21 AM |
"Refining" a fuel gauge reading
Hi All
I'm looking to calibrate the reading on a fuel gauge but retain the existing sender. I assume this is easy enough using a potentiometer and
I've a reasonable understanding of the required resistance but no idea of the kinda wattage required. Any advise greatly appreciated!!
J
40inches
posted on 1/2/14 at 12:00 PM |
You can buy them. CBS. But they aren't cheap
theprisioner
posted on 1/2/14 at 12:16 PM |
Power is calculated V^2/R. Max power in tank and gauge is when the value = gauge resistance usually at empty. If your gauge reads correctly when full
(0 ohms) you stand a chane of correcting it as the sense of the sender and gauge are the same. What does the gauge read when empty and what are the
respective resistances measured on a digital ohm meter?
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
chrism
posted on 1/2/14 at 12:31 PM |
Can you not adjust it by making the arm on the sender longer or shorter and bending it so it reads out the correct resistance for your gauge.
A little hard work never killed anyone, but why take the risk!
whitestu
posted on 1/2/14 at 01:39 PM |
+1 - bend the arm until it reads right
40inches
posted on 1/2/14 at 02:04 PM |
The resistance range in the sender and gauge have to be the same, bending the arm doesn't change the resistance, only the level reading. To get
mismatched resistances to read correctly only some form of electronic trickery will work
chrism
posted on 1/2/14 at 05:25 PM |
If the resistance levels required by the gauge fall within the levels created by the sender then it would be possible by bending and adjusting the
length of the arm to match the swing to the required resistances, if that makes sense, i.e. a longer arm would give a shorter throw from empty to full
and a shorter arm would give a longer throw on the sender.
40inches
posted on 1/2/14 at 05:28 PM |
Ah! That would probably work, using the top and bottom of the tank as stops for the float?
chrism
posted on 1/2/14 at 07:37 PM |
Yes, just relies on the sender being in about the right range and resistance going in the right direction for the sender.
