Author: Subject: Formula 27 zetec digital dash
Plunky
posted on 6/2/14 at 10:53 AM Reply With Quote
Hi, my F27 is fitted with a 2.0 zetec/bike throttle bodies and a type 9 box.
I am looking to get rid of the standard dials and replace with a digital dash, it currently appears to be a standard ford dash cluster stuck behind the dash and some holes cut in the dash to display the rev counter and speedo. There is also a fuel gauge and coolant temp gauge.
Can anyone suggest a good all round digital dash display that will be compatible with my current engine/gearbox set up? I will be making a new dash from Carbon fibre sheet to fit the new dash in.
Thanks in advance,
Liam
serieslandy
posted on 6/2/14 at 11:27 AM Reply With Quote
It all depends what kinda thing your after and budget.
I personally like the race technology dash 2 or pro but it's expensive but very customisable and your standard sensors should work. Except the speedo (you will need a Hall effect sensor)
The ace well dashes look good and arnt that expensive. Try here for them
Lots of people like the etb instruments dash as well but I can't comment on that one.
[Edited on 6/2/14 by serieslandy]
loggyboy
posted on 6/2/14 at 11:53 AM Reply With Quote
Ive heard nothing buy good things about the ETB digidashes.
Im not in the stage of build to need one, but its currently top of my list of dash options.
Mistral Motorsport
Plunky
posted on 6/2/14 at 12:10 PM Reply With Quote
Thanks guys - a friend of mine had an ETB dash in his MK indy kit car - very impressive bit of kit, I just don't really want to spend that kind of money though.
I suppose £150 is the maximum really - it has only really got to do the basics - Revs / speed / fuel / temp / backlit display - anything extra is a bonus.
I have found this http://www.digital-speedos.co.uk/db02r-multi-function-rpm-speed-temp-etc-121-p.asp
any opinions on this?
Plunky
posted on 6/2/14 at 12:15 PM Reply With Quote
Loggyboy - did you used to drive a Nova by any chance?
bi22le
posted on 6/2/14 at 12:43 PM Reply With Quote
Yes he did,
Dont get him started. He will be bleating on about it all day!!!
Please read my ring story:
