CompoSimmonite
posted on 13/2/14 at 05:17 PM |
Using trailer wiring for loom ?
I intend making a new harness for my Marlin. Rather than spending a small fortune on all the traditional (Lucas ?) colour codes the idea was to use my
own combinations based on 13 core towing electric colours. Then I had another thought - why not use trailer wiring ! Heat shrink coloured bands could
be use at either end of the wire to identify.
Obviously I don't know the number of strands so that aspect would need checking.
So question therefore is good quality (say Durite or similar) 13 core trailer wire suitable ?
Paul H
ali f27
posted on 13/2/14 at 05:35 PM |
its what i used to take wiring front to back on my car worked a treat
jacko
posted on 13/2/14 at 05:39 PM |
Why not there is no reason you can't use trailer cable.
The only thing is you have to have the odd wire coming out half way down the tunnel for the hand brake light switch
Jacko
Myke 2463
posted on 13/2/14 at 05:42 PM |
Got mine from http://www.vehicle-wiring-products.eu/VWP-onlinestore/cable/multicorecable.php#trailer
8 years and no problems.
Be Lucky Mike.
renetom
posted on 13/2/14 at 05:53 PM |
Hi
Should be ok for nearly all the wiring
We used 17 amp for everything exept
Dipped , main beam & horn which we used 25 amp
Trailer wire must be around 17 amp ?
good luck
TimC
posted on 13/2/14 at 05:55 PM |
Yep, like this:
A cheap source of wires when stripped of outer sheath also.
Russell
posted on 13/2/14 at 06:37 PM |
I reckon you should run separate cores for:
Left brake light
Right brake light
Left tail light
Right tail light
Reversing light
Fog light
Left indicator
Right indicator
That's 8 cores, and use the chassis as the negative return. And the reason why? It's good practice to wire and fuse both brake lights
and both tail lights separately (4 fuses) so if a fuse goes it only takes out one lamp on one side at a time.
I'm a bilingual illiterate. I can't read in two languages.
CompoSimmonite
posted on 13/2/14 at 07:31 PM |
Thanks for replies.
Looks like trailer wiring will be the way I go then
The 13 core gives plenty of choice for circuits -
red, brown, green, yellow, blue, black, pink, white and blue, grey, orange, white, white and red, white and black.
That means enough circuits for rear light, fuel sender, reversing light and more to rear.
Hand brake will be pull type (probably Ford Ranger item) on dash so there will be no need to cut into the main front to rear section.
Paul h
Trollyjack
posted on 18/2/14 at 09:29 AM |
I used trailer wire
How are you going with Tiny CAD
TrollyJack
Smoking Frog
posted on 18/2/14 at 01:23 PM |
I also used trailer cable, fine for lighting and small current load. I run a separate higher rated cable to the HP fuel pump.
