killerferret666
posted on 23/2/14 at 09:12 PM |
Horn switch wiring with savage switch
I'm using the cbs fuse board, the fuse board gets you to place a switch on one connection to earth.
This goes through to the horn relay.
I can't wire the savage switch correctly either the light is on all the time, or the LED in the switch doesn't have a high enough load to
engage the relay coil.
I need a way of wiring it so light is on when pressed but the load through the switch is high enough to trigger the relay coil.
Building DDR GT4
Miami Gt4 Blog - Click Here
Ben_Copeland
posted on 23/2/14 at 11:10 PM |
The easiest way is to use the 6 connector relay that sometimes come with the savage switches. They contain 2 separate relays, one side can switch the
horn, the other side switches the light.
I've just done something similar with my manual fan control
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
killerferret666
posted on 24/2/14 at 08:10 AM |
Unfortunatly it only came with a 3 pin (single sided effectively) switch / relay and not the 6 pin that came with the hazard switch, otherwise your
right the solution would be easy. I wonder if i can buy them seperately.
Building DDR GT4
killerferret666
posted on 24/2/14 at 12:42 PM |
just ordered a double throw switch to go on it instead....easiest solution!
Building DDR GT4
