tims31
| posted on 7/3/14 at 07:43 PM |
ARRRGGG Help please-Starter/alternator/Battery
Hi Guys,
Hopefully someone understands what I am trying to say and the diagram explains better what I am trying to do.
I have managed to get myself really confused with the wiring of my kit and could really do with some help before I end up chopping something out I
shouldn’t.
I have a Premier wiring Loom but have got stuck with how to wire up the starter, alternator and ignition. Using the diagram shown below or (from the
pdf in the link), could some please tell me which way I should connect this all up to the battery, alternator, starter loom and ignition cable.
Although I am using the key to switch the ignition on I would also like to use a push button but not sure where to wire that in the cabling from the
ignition switch.
Also what are the two yellow cables from the ignition plug for?
I will be wiring this up to the standard Ford/Zetec loom system too just in-case that needs to be considered?
  wiring-question
Diagram in PDF
Thanks for any help you can provide
Build: http://www.martinsfurybuild.co.uk/
big_wasa
| posted on 7/3/14 at 08:02 PM |
quote: Originally posted by tims31Also what are the two yellow cables from the ignition plug for?
In short you don't need the yellow wires. It is for the accessories, ie the car stereo and interior lights ect. When cranking the engine it cuts
power to these to provide max juice to things like the ignition and the starter.
The oem Immobilizer does allow you to immobilize the starter motor so could be a consideration in your wiring if you want this feature ?
I have to nip into work for a couple of hours sunday, I am passing on the way home if your about ?
tims31
| posted on 7/3/14 at 09:56 PM |
Hey Wasa
That would be great, any help much appreciated. have a footie match in the morning with my lad but should be in after 1pm if that suits. Thanks mate
