neilp1
posted on 30/4/14 at 08:02 PM |
Hazards and indicator problem
My problem is - hazards work fine with ignition off. When I switch ignition on the hazards are on. If I remove the hazard switch I still have the
problem, but when I disconnect wiring from sierra indictors stalk hazards work fine with/without ignition on. I'm using a tiger supplied loom
and digidash2 lite.
Anyone come across this problem?
[Edited on 30/4/14 by neilp1]
teegray19
posted on 30/4/14 at 08:35 PM |
Sounds like your feeding switched live back into the hazard circuit somewhere. I used a diode to fix my problem but I knew where the leak was.
I think you will need a diode but it's just finding where to put it
Built Formular 27 with 1600cc crossflow, 1700cc 0 miles crossflow, Kawasaki ZZR1100
Jon Ison
posted on 30/4/14 at 08:57 PM |
I had a similar but not exactly same problem, indicator stalk was the culprit.
neilp1
posted on 8/5/14 at 04:44 AM |
All fixed now. I had wired the telltale wiring straight to digidash. Once I added the telltale warning lights and a feed off them it worked fine!
