ali f27
posted on 4/5/14 at 08:36 AM |
starter problem
Hi starter has developed a problem it engages turns over one time then then disengages with the flywheel and just spins any thoughts
Cheers Ali
posted on 4/5/14 at 09:23 AM |
Cheers Ali
What engine & starter type.
If it is an xflo with an inertia 2 bolt starter then it could be caused by the sandwich plate between engine and gear box being omitted when the
engine and gearbox were mated up.
ali f27
posted on 4/5/14 at 09:33 AM |
Hi duratec has been fine for about 2 months just started doing it yesterday
JacksAvon
posted on 4/5/14 at 10:45 AM |
A poorly fitted starter on my 2lt zetec has chewed a secton of teeth out of the ring gear.
May be worth taking the starter off and looking at the ring gear
