chrisxr2
posted on 5/5/14 at 09:29 PM |
Speedo malfunctioning??
Unsure if this is electrical or mechanical. Electronic speedo now reading vastly out, only really reads upto about 40mph, regardless of actual speed.
Not had chance to have a proper look, any guesses at speedo or other end as pis sibyls cause??
Life moves pretty fast, if you don't stop and look around once in a while, you could miss it.
olimarler
posted on 6/5/14 at 05:47 AM |
Not sure what type you have but check magnets on prop shaft. If ones come off then this could cause a problem.
Barkalarr
posted on 6/5/14 at 06:19 AM |
I've just changed my speed sender - I did have a 2 wire reed switch and now swapped it with a 3 wire switch. Before, the speedo used to jump
around all over the place - now it's solid as rock!
So, it could be a knackered sender ?
pekwah1
posted on 6/5/14 at 09:44 AM |
Is it reading correctly up to 40mph?
I had a problem with mine before where the bracket that held the sender had moved slightly away from the prop.
Was fine at lower speeds, but as soon as i got to higher speeds, just dropped to zero.
Turned out the sender was too far from the magnet and wasn't getting a good reading
chrisxr2
posted on 6/5/14 at 09:50 AM |
Not reading upto 40
Pekwah ah, it's not reading correctly at any speed, just shows a maximum of around 40 regardless of how fast you are actually going.
[Edited on 6/5/14 by chrisxr2]
pekwah1
posted on 6/5/14 at 10:18 AM |
what speedo and sender are you using sir?
chrisxr2
posted on 6/5/14 at 05:35 PM |
Need to check
Need to go and check, bought car built.
