blakep82
posted on 8/6/14 at 09:04 PM |
13 pin trailer socket size
Does anyone know the outer size (diameter) or this type of 13 pin trailer socket?
I'm using 7 pin ones on my bulkheads for lights and engine electrics, but could do with more than 7 pins for the engine electrics, really
[Edited on 8/6/14 by blakep82]
________________________
JohnH
posted on 8/6/14 at 10:18 PM |
Think they are the same size as the 7 pin ones.
blakep82
posted on 11/6/14 at 11:32 AM |
Awesome, cheers.
I can fit a 7 pin socket, but need more pins, so hopefully its not any bigger!
SteveWalker
posted on 11/6/14 at 02:02 PM |
It would make sense for them to be the same size, as anything different may not fit on all towbars without fouling bracketry, bumpers, etc.
posted on 11/6/14 at 08:27 PM |
That is quite a large socket for a small number of pins.
I used a 20 way pc power connector for my dash; see link to maplins./ you buy the pack of pins separately.
You can always double up the pins for earth etc.
linkyh: http://www.maplin.co.uk/p/maplin-atx-motherboard-female-power-connectors-l70az
Check my lost about thiz ... will be a few years avo.
[Edited on 12/6/14 by 02GF74]
blakep82
posted on 11/6/14 at 08:54 PM |
I used. A 20 way pc connector fkr my dash. You can akwahs doubls up the linx fkr earth egc.
True, but they're also screw down connections, no fiddly pins to crimp. Just a bootlace terminal, and screw in.
I'm sick of the sight of superseal pins now!
Edit- aw wait, do you mean the screw down ones in a long strip?
Can they take the currents of starters and lights ok?
[Edited on 11/6/14 by blakep82]
posted on 12/6/14 at 04:14 PM |
Need to dig the info out but it is a power connector.
Pins a rated at a couple of amps so ok for instruments. I don't think i have high current leads connected such as headlamps, starter but buy
using a relay those items could be switched.
ashg
posted on 12/6/14 at 06:21 PM |
The 13 pin ones push and twist in not just push. They are the same size externally as the 7 pin ones .
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
posted on 12/6/14 at 09:03 PM |
see here:
http://www.locostbuilders.co.uk/viewthread.php?tid=76404
shows the white connector that I used.
