luke2152
posted on 17/6/14 at 11:26 PM |
wiring tacho
Have a small 'universal' cheap tach from ebay. It is 4 wired (-,+,lamp, signal). Comes with no instructions. mk1 MX5 engine. Where
should I run signal to. I'm guessing not straight to HT leads. One of the coil wires maybe? Or perhaps off the cam angle sensor?
snapper
posted on 18/6/14 at 04:50 AM |
I eat to survive
I drink to forget
luke2152
posted on 18/6/14 at 11:02 AM |
Thanks. But do I need to take the signal off both coils? I take it the diodes are to stop the needle jumping around?
r1_pete
posted on 18/6/14 at 11:56 AM |
Yes, you need to take a feed from each coil pair, in a 4 cyl setup you need two ignition events per revolution.
The diodes are to prevent cross firing the coils.
Smoking Frog
posted on 18/6/14 at 12:31 PM |
If using MX5 ECU it has a signal wire for the tachometer.
Edit
Hang on, I think it comes from the igniter not ECU. Pin D yel/blu wire.
[Edited on 18/6/14 by Smoking Frog]
luke2152
posted on 18/6/14 at 12:47 PM |
Could just set tach to 2cyl and use one coil and just the zener diode? Im using megasquirt but didn't make the internal links for tach if i
remember right so ill just go off coils
[Edited on 18/6/14 by luke2152]
