Joelove
| posted on 19/6/14 at 06:32 AM |
Battery for bec?
Hi what size battery should I use for a bec build?
I know the bike has a small battery but I presume the electric reverse is going to take a lot of cranking power considering it's got tho move
the car and person!
What cranking power if a battery should I be looking for?
theprisioner
| posted on 19/6/14 at 07:46 AM |
I have a BEC with a racing battery, it has an electric reverse based on what looks like a motorbike starter. I also have a trackside battery connector
on the dash. If I am planning on doing a lot of reversing then I pug in a battery pack while doing it. That eliminates the weight of a substantial
battery just for reversing. However I hate using the electric reverse, it is not well designed and sounds like a spin dryer with marbles inside. The
racing battery gets me out of tight parking type manoeuvres but don't plan on more than 20yards usage.
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
40inches
| posted on 19/6/14 at 08:05 AM |
I have a Varta B34 330ca, fits nicely in the passenger foot well with plenty of leg room.
Joelove
| posted on 19/6/14 at 09:38 AM |
Hmm couple of options then.
Just wanted to keep weight down, and a bike battery would be enough for the running but wasn't sure it was good enough to do the reverse aswell,
bet it takes some power to reverse the car
Ben_Copeland
| posted on 19/6/14 at 11:22 AM |
As long as you keep the engine running it shouldn't be too much of a problem
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
Joelove
| posted on 19/6/14 at 11:41 AM |
As in using the bikes original battery? I'm using a Vw starter
