kj
posted on 24/8/14 at 05:55 PM |
magnets
How do you stick your magnet's stuck them down but keep flying off what you used ?
Think about it, think about it again and then do it.
wylliezx9r
posted on 24/8/14 at 06:08 PM |
3m dp 609, 2 part adhesive is what I used. 2 years and still going on a driveshaft.
George Best
posted on 24/8/14 at 06:09 PM |
File it a little were you want it, that gives it a clean rough flat and araldite the magnet on it.
Is it on the prop?
CNHSS1
posted on 24/8/14 at 07:59 PM |
If using Araldite (or the majority of 2 part epoxy glues) the 5min rapid set versions are tinately lower strength than the 12/24 hr versions
SteveWallace
posted on 24/8/14 at 08:24 PM |
As per Coozer, I used a file to get a clean but rough surface. I then used slow setting araldite (which means that you can only do one a day, as it
need to be on a horizontal surface). I placed them on the output flange of the diff rather than the propshaft side on the basis that they would be
rotating 3.62 (Sierra LSD) times slower and therefore less likely to fly off. There was also a convenient lug on the diff to attach a bracket for the
sensor
![](/galpreviews/speed sensor location.jpg) ![speed sensor location](/gallery/speed sensor location.jpg) speed sensor location
owelly
posted on 24/8/14 at 08:35 PM |
I drilled a little recess and bonded the magnet into it. Two-part epoxy and a wrap of duct tape around it to hold it tight.
http://www.ppcmag.co.uk
wicket
posted on 24/8/14 at 08:46 PM |
As Owelly, been on 8 years now with no prob.
SteveWalker
posted on 24/8/14 at 09:37 PM |
I used a sensor from RS (can't remember the model number) and it happily reads the bolt heads without any magnets.
whitestu
posted on 25/8/14 at 10:36 AM |
I used epoxy and a cable tie on my prop. Works perfectly.
