Author: Subject: Voltage stabilizer
Greenie
posted on 28/8/14 at 08:12 PM Reply With Quote
Voltage stabilizer
Where can I get a voltage stabilizer from, checked the usual eBay but no sign, can anyone help and do I need a particular one or are they all the same?
theprisioner
posted on 28/8/14 at 08:34 PM Reply With Quote
Most stabilisers regulate at 10V, a 3 terminal regulator from RS components and two resistors will do the same job.
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
ReMan
Application?
"Voltage regulator"?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
big-vee-twin
posted on 28/8/14 at 10:02 PM Reply With Quote
If your talking for smiths guages - speedy cables.
http://www.triangleltd.com
ReMan
posted on 28/8/14 at 10:16 PM Reply With Quote
VOLTAGE REGULATOR - 7805 7808 7809 7812 5V 8V 9V 12V PACKS OF 3, 5 OR 10 New UK
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
coyoteboy
posted on 29/8/14 at 05:06 PM Reply With Quote
Woah woah woah back up chaps - what the application and do you want an off-the-shelf answer or to build the circuit.
You want a lot more than a simple voltage reg and caps/resistors if it's going in an automotive environment - the spikes and dips you see on car circuitry are brutal.
theprisioner
posted on 29/8/14 at 05:11 PM Reply With Quote
Ordinarily your advice is excellent but these regulators have very good common mode rejection of noise provided you put in a couple of caps. They can also stand 60V on the input if selected correctly.
Greenie
posted on 29/8/14 at 05:20 PM Reply With Quote
You are all losing me now, just after a voltage reg for a car with a 12v system with a triumph dolomite part loom.
ReMan
In the absence of more detail from the OP, I think were enjoying playing "20 questions" or should we say answers!
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
Greenie
posted on 29/8/14 at 05:22 PM Reply With Quote
Ha ha ha exactly...... But thanks to all... So much knowledge!
ReMan
posted on 29/8/14 at 05:31 PM Reply With Quote
So do you need a voltage regulator to go with a dynamo?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
old_timbo
posted on 29/8/14 at 10:40 PM Reply With Quote
Think this is what you want:- Semiconductor Voltage Stabilizer- TR4 TR5 TR6 Dolomite
Works great and much better than the original Smiths effort which reduced / regulated voltage by a vibrating bimetallic strip I use one with my Dolomite gauges.
FEZ1025
posted on 15/9/14 at 10:26 AM Reply With Quote
Or one like this classic car voltage stabiliser 10 VOLTS 1 AMP OUTPUT
Alan...
