GreigM
posted on 31/8/14 at 03:50 PM |
Diagnose my duratec misfire
Just looking for clues as I'm under a bit of a deadline to get this fixed.
2L duratec
On a track day today, car starts and runs fine. Do the session on track, all seems ok, but on the cool down lap back to the pits the car is misfiring
quite badly. Get back to the paddock, it idles fine and when under heavy throttle (above 4000 rpm) seems fine, its only under partial throttle that I
get this misfire.
I let the car cool down over lunch, start it up, all seems fine - revving up fine under partial or full throttle so go out for another session, car
running well, again on the cool-down lap under partial throttle the misfire returns.
So symptoms seem to be:
HOT car
partial throttle misfire
idle fine, WOT fine
Plugs are new (<300 miles), so I'm leaning towards HT leads or coil pack - any other suggestions? Are there any sensors I should be thinking
about replacing also (I'd rather spend money and get it fixed quick)?
owelly
posted on 31/8/14 at 03:59 PM |
Could it be fuel getting hot in the rail or fuel lines or has this set-up been OK in the past?
http://www.ppcmag.co.uk
GreigM
posted on 31/8/14 at 04:13 PM |
All been fine, no issues previously on other track days.
I'm kinda ruling out fuelling issues (maybe wrongly) as it runs fine at higher revs (meaning there is enough fuel getting through) - my simple
mind thinks this must be electrical.
scudderfish
posted on 31/8/14 at 05:09 PM |
At WOT the fuel will be flowing through the rail. I don't know the duratec, but if the rail is dead-ended (i.e. no return from it) then fuel
will be lingering and potentially vapourising in a hot rail
GreigM
posted on 31/8/14 at 05:56 PM |
Ok, understand and could be a possibility however I never had this problem before on hotter days with longer sessions. Previous owner never had it
either and I'd bloody hope for the price of their cars Caterham would design the fuel rail better than this!
I'm going to nip out and examine the plugs shortly, just to make sure one of them hasn't had an issue..but as I said they are fairly new
so wouldn't think so.
jacko
posted on 31/8/14 at 06:04 PM |
Wot make of plug's are you using ?
GreigM
posted on 31/8/14 at 06:44 PM |
Denso IT24 iridium
Think I may have found the issue, photo on the way
GreigM
posted on 31/8/14 at 06:56 PM |
Would this cause the issues I have? #2 HT lead has been pinched by the screw holding on the cover - i has taken off some rubber outer and I can see
the green rubber inner (although I can't see any metal). I'll replace it anyway as a matter of course, but just need to know if i can
stop looking for other things to replace.
[Edited on 31/8/14 by GreigM]
jacko
posted on 31/8/14 at 07:19 PM |
YES think you have found the problem
GreigM
posted on 31/8/14 at 07:35 PM |
Next question - are fancy Magnecor HT leads worth their money?
itsawindupuk
posted on 31/8/14 at 09:40 PM |
Id say so, I have them on my duratec, very thick insulation, look great and the quality of the plugs is spot on. They should last a very long time.
Also you can have them made to any length you want.
