AntonUK
posted on 10/9/14 at 09:28 PM |
Headlight Wiring...
Two quick wiring questions...
1. When you switch on dipped headlights, should the sidelights go off (I believe not)?
2. When you switch on main beam, should the dipped lights go off (I believe this is yes)?
Build Photos Here
The Black Flash
posted on 10/9/14 at 09:40 PM |
1) No
2) Depends on the bulbs. If it's a single bulb with both filaments in, then yes. If you have separate main and dip lights, then either way is
fine.
adithorp
posted on 10/9/14 at 09:47 PM |
1. Yes, side should stay on with headlights on.
2. Depends.
If you have single dip/main units (using a twin filament H4 bulb) then only one filament should be lit. If not the bulb will soon overheat.
If you have twin lamps (one dip, one main per side with a single filament H7 bulb each) then the dip can stay on when main beam is on.
http://jpsc.org.uk/forum/
johnnybizzle1986
posted on 14/10/14 at 02:53 PM |
sorry to jump onto this thread but its regarding my headlight wiring. The last bit to finish
Im using sierra stalk switch gear
Ive got permenant power to side lights in the switch position on the sierra stalk - no probs there
Ive got two relays set up for dipped and beam which work ok when i put a wire to the batery as a test - no probs there
Where im struggerlng is getting power to the headlight switch on the right hand stalk, do i use one the grey wires from the sides linked to one of the
black and brown earth leads and then the other link to 56 on the other stallk
Any help much apprieciated
Regards jon
