Author: Subject: Mega fuse size
CosKev3
posted on 5/1/15 at 09:04 AM Reply With Quote
Mega fuse size
I'm fitting my battery in front of the engine, so I have a long run of cable from battery to electric reverse on rear joint of prop to diff.
So I'm fitting a Mega fuse in the battery box for protection.
Question is what size fuse is required?
Do you take into account battery amps, or rating of cable that's going from battery?
bart
posted on 5/1/15 at 09:20 AM Reply With Quote
you cant fuse the starter its self .depending on model and the hill size could be 200 to 600 amps
just double insulate the cable.. run next size up cable as well for volt dropage.
BE ALERT > BRITAIN NEEDS LERTS
bart
posted on 5/1/15 at 09:25 AM Reply With Quote
ps: battery amps are in theory unlimited. just limitted by internal resistance of battery.
could be 800 + amps
thats why if you short a spanner over the terminals it will melt !
Staple balls
posted on 5/1/15 at 09:38 AM Reply With Quote
This suggests 150 or 250A, But I suppose it depends on your motor, and of course, your wiring, there's no point putting a 500A fuse in there if it's hooked up with speaker wire.
JAG
posted on 5/1/15 at 12:52 PM Reply With Quote
You can calculate how much power is required to reverse your car.
Calculate the torque needed then multiply that by the maximum speed you want the car to move at.
Allow for the worst case; maximum vehicle weight reversing UP a 33% hill.
If you divide that number (in Watts) by the voltage available it will tell you the current draw.
Make sure that your wire size is bigger than necessary for this current draw.
Then select your fuse to be the same size as the maximum expected current draw.
Justin
James
posted on 5/1/15 at 05:53 PM Reply With Quote
If you want to go the scrappy route then I guess something like a 5 or 7 series Beemer that has the battery in the boot might be able to supply cable and parts to match.
HTH,
James
907
posted on 5/1/15 at 06:08 PM Reply With Quote
Or MX5
DW100
posted on 5/1/15 at 07:23 PM Reply With Quote
Be aware that BMWs may well have pyrotechnic battery terminals.
Not a joke they are fired in an accident to disconnect the battery.
posted on 5/1/15 at 08:42 PM Reply With Quote
Check this thread and have a look at my pictures a bit down.
250A for the starter post.
http://locostbuilders.co.uk/viewthread.php?tid=194619
CosKev3
posted on 6/1/15 at 09:55 PM Reply With Quote
Thanks all,I'll fit a 250amp as it's 40inches old reverse system I bought
There's a proper answer to my question!!!but buggered if I can work all that out!!!!
