Chris_Xtreme
| posted on 16/1/15 at 11:35 PM |
cbr600rr4 TPS wiring?
hi
I've got this pic from the cbr600rr3 manual, the wire colours match the one from the cbr600rr4 TPS I have, so I am going with they are the
same.
Can anyone advise which is ground, constant and signal? (wiring up to megasquirt)
thanks
  cbr600rr3_TPS
[Edited on 17/1/15 by Chris_Xtreme]
simonrh
| posted on 17/1/15 at 07:48 AM |
R/y is signal and then g/o is 0v, y/r is positive I believe. If the last 2 end up arse backwards (ecu is seeing full throttle when it is closed)
then you can swap the 0v and 5v.
Chris_Xtreme
| posted on 17/1/15 at 09:14 PM |
Nice, thanks for the info. Going to use a connector block until tested.
Cheers fellow xtreme owner
Chris_Xtreme
| posted on 5/2/15 at 10:49 PM |
worked a treat
simonrh
| posted on 6/2/15 at 06:56 AM |
Perfect, I have been taking my time over getting my nodiz in and running but will have to cross the tps bridge at some point too.
