bowood14
posted on 17/1/15 at 06:29 PM |
WTD: really simple wiring diagram for megajolt E with zetec engine
Bearing in mind I'm not a mechanic or electronics engineer Does anyone have a really simple wiring diagram for a megajolt E on a Zetec engine.
So this will be the Megajolt, edis, coil, crankshaft sensor and TPS
I've looked at this but still a little confused!! Doesn't take much to confuse me
http://www.autosportlabs.net/MJLJ_V4_vehicle_installation_guide
Any help gratefully received
Thanks Adrian
blakep82
posted on 17/1/15 at 06:37 PM |
Hmm, I would say those diagrams are the best you're going to get. Aside from what they contain, the rest is about where you place the
components.
This one is the key one
http://www.autosportlabs.net/images/5/59/EDIS_Module_harness.png
As a wiring diagram, it doesnt really get any more simple, get it to run on that (ignoring the pip and saw connections for now)
It'll start and run on that, if it does, add the pip and saw
http://www.autosportlabs.net/images/9/9f/Mjlj_v4_minimal_pinout.png
Plug the mj into the pc to check its giving live engine speed datdata etc
Then the throttle position
http://www.autosportlabs.net/images/b/bf/Mjlj_v4_tps_pinout.png
Take it in steps
[Edited on 17/1/15 by blakep82]
________________________
bowood14
posted on 17/1/15 at 07:11 PM |
Thanks for the advice I will start drawing on a piece of paper and see how it goes.
Update !! done my drawings on A4 paper, measured up the lengths of wire required now to start putting it all together
[Edited on 17/1/15 by bowood14]
blakep82
posted on 17/1/15 at 09:16 PM |
Nice!
Its pretty straightforward. Have fun
Just watch the connection I f your crank sensor. The engine will not run if the wires are the wrong way round
