rayroni
posted on 1/12/04 at 08:17 AM |
Fitting Brake Light Pressure Switch
When fitting a brake (light) pressure switch into a 4 way brake union - should I fit a copper washer?
Tar,
shortie
posted on 1/12/04 at 08:39 AM |
I didn't an it's fine, I think I used a bit of PTFE tape
Rich.
posted on 1/12/04 at 09:43 AM |
I didn't fit one and it doesn't seem to leak. I think the brass is probably soft enough to form a good seal when you tighten it up.
HTH
Nick
bob
posted on 1/12/04 at 10:18 AM |
I used a little PTFE plumbers tape for a bit of security but i think as said the copper will make a good seal.
