Ivan
posted on 8/7/15 at 09:36 AM |
Starter motor won't stop running
Been busy tuning my Chevy V8 EFI - starting and stopping regularly when all of a sudden the last time I tried to start it the starter motor started
running without engaging and the only way to stop it was to cut the battery supply. I suspect it's something to do with the solenoid
that's somehow stuck on switching on the motor but not activating the engagement mechanism. Won't switch off via the ignition switch but
only via the battery cut-off switch.
Any thoughts on this - I will pull the starter later this week to inspect.
theprisioner
posted on 8/7/15 at 10:18 AM |
I that what Formula1 use in the drs zone
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
HowardB
posted on 8/7/15 at 11:26 AM |
sounds like an over heated solenoid, hitting it a controlled fashion may be your friend
Howard
Kdempsie
posted on 8/7/15 at 12:09 PM |
How is your battery voltage?
If you've been starting and stopping a lot and the voltage is down this can cause arcing in the solenoid contacts. The solenoid is not pulled in
quickly enough and the currents are increasing essentially welding the contacts together.
A couple of sharp taps with the hammer might free it as mentioned.
This assumes that the small switching wire is not just shorted to +12V somewhere unintentionally operating the starter.
A quick check with a multi meter should help identify if it's welded together or unintentionally switched.
Keith.
Oddified
posted on 8/7/15 at 04:51 PM |
If the starter disengages/stops after the main power is momentarily interrupted then it can be one of the solenoid coils partly burnt out
(there's effectively 2 coils in a solenoid, one to engage everything and a lighter one to hold it once engaged).
Ian
posted on 10/7/15 at 01:11 PM |
I would suggest disconnecting the cable from the ignition switch at the solenoid when the starter is playing up to eliminate a faulty ignition switch
before condemning the solonoid
posted on 10/7/15 at 02:04 PM |
+1
2 minutes with a DMM or a test lamp could save a lot of work.
Also if the solenoid has a ballast bypass connection incorrectly connected that could case the starter solenoid to latch on.
Ivan
posted on 11/7/15 at 10:32 AM |
Thanks for all the feedback.
Took it out and it was working fine on the bench - Google search shows that it's a common problem with these starters - seems that the solenoids
used (Chinese copies of Nippon Denso ones I believe) don't like heat so maybe tuning idling whilst car was standing caused heat sink problems
because now that it's cool it's working fine when installed. Looking at heat shields or searching Toyota and Nissan spares suppliers for a
quality replacement.
Also looking at opening it up to see if anything obvious to be seen or if a bit of lubrication might help.
