mangogrooveworkshop
| posted on 7/12/04 at 09:34 PM |
MNR Fuel sender dia
Any one got any idea what size hole in the tank the mnr fuel sender requires?
[Edited on 8-12-04 by mangogrooveworkshop]
scoobyis2cool
| posted on 8/12/04 at 10:11 AM |
Big enough to fit everything through but small enough so there's still some material left to screw into to mount it?
But seriously, the top looks identical to mine, which needed a 44mm hole if I recall correctly. If it came with a rubber gasket, measure the inside
diameter of that, that's about the size you want your hole
HTH
Pete
ned
| posted on 8/12/04 at 10:16 AM |
look slike the racetec sender to match their racetec fuel gauge, check out racetec's website, maybe have details on there..
Ned.
beware, I've got yellow skin
mangogrooveworkshop
| posted on 8/12/04 at 12:19 PM |
thanks lads
