matty h
posted on 20/9/15 at 01:14 PM |
alternator fault
I have an alternator that does not charge the battery measured same voltage as battery on the output terminal but on the teminal for the change light
is 15 volt anyone know why this happening and what is wrong.
Thanks Matty
gremlin1234
posted on 20/9/15 at 01:24 PM |
does the light on the dashboard work?
matty h
posted on 20/9/15 at 01:29 PM |
Yes comes on then goes off.
posted on 20/9/15 at 04:11 PM |
What type of alternator is it ? If is the Lucas-Mangneti Marelli A127 used on the earlier K series changing the alternator regulator complete with
brushes is a 10 minute job.
matty h
posted on 20/9/15 at 04:19 PM |
Of a land rover 300tdi.
posted on 20/9/15 at 05:26 PM |
That could be either Denso or Lucas-Mangneti Marelli both are diy rebuildable provided you have a decent sized soldering iron there is an Irish
seller on eBay sells all the bits cheaply and has instructional videos on YouTube.
matty h
posted on 20/9/15 at 08:12 PM |
Is a Lucas-Mangneti Marelli have blown it out with compressed air and refitted and now wrking.
May take a look for the parts on e bay.
Thanks Matty
