keith2lp
| posted on 11/12/04 at 01:24 PM |
Wiper motor to sierra column
Hi
Can anyone help me?
I have a lucas 2 speed wiper motor and I was wondering if I can wire it into the sierra column switch and still get it to park.
Keith
[Edited on 11/12/04 by keith2lp]
| posted on 11/12/04 at 01:44 PM |
Why not?
It should park anyway, the mechanism is in the motor not the switch.
zetec
| posted on 11/12/04 at 04:42 PM |
You can get it to work 2 speed, intermittant wipe and park if you use the Sierra switch and relay. I cheated and used a Premier wiring loom. I'm
sure I've seen a diagram on either SVC web page or some other kit site, worth a search. Failing that give Premier Wiring a call, top bloke might
help you out.
| posted on 11/12/04 at 05:44 PM |
I used a premier loom as well , using a Lucas 2 speed motor and Sierra switch's is no problem. Think the robin hood site gives details of the
motor connections. Hope this helps , Rusty
keith2lp
| posted on 11/12/04 at 06:25 PM |
Hi
Thanks for the info.
I have the luego loom and I can get the motor to run at both speeds but I cant get it to park as I am unable to find where to wire the park supply in
to .
Any help would be appreaciated.
Keith
| posted on 12/12/04 at 11:17 AM |
As I said earlier.
The mini wiper, which I assume you have, doesn't have a seperate wire it has a limit inside to keep the current open till the wiper reaches the
down position. Here's a diagram of it . If it isn't a mini one or it's a very early mini which didn't have a self park I
can't help.
[Edited on 12/12/04 by Peteff]
keith2lp
| posted on 12/12/04 at 08:14 PM |
All Sorted Now
Hi
Thanks for the help, I have now got it to work I found the park feed which was totaly different to the haynes manual for my age of switch.
Good old ford they just love standardisation!!!!!!
Keith:D
[Edited on 12/12/04 by keith2lp]
