tajgreidotu
posted on 26/10/15 at 07:27 PM |
LHD headlights
Hi guys,
My build is advancing fast now, and its time to start thinking about headlights.
I understand that as the car will be LHD, and trying to avoid legal problems, I should look for LHD headlights and E-marked.
I had a look but to be hones I didn't even find one possibility.
Any idea about this?
gremlin1234
posted on 26/10/15 at 07:45 PM |
you need the lights to suit local roads,
left hand drive/ right hand dip are available, here's a uk supplier
http://www.minispares.com/product/Classic/XBC103410.aspx
but seven inch headlights fit many many things so you should be able to source them locally.
loony
posted on 26/10/15 at 08:34 PM |
I bought pair of this for my Haynes Roadster:
They are Polish WESEM 161mm headlights for Ursus/Zetor agricultural machines, E-marked, so maybe you are able to buy them locally in Bulgaria.
They accept H4 bulbs, so ignore old fashion R2 bulb at the photo.
http://shop.wesem.com/en/3/6716/headlamps_pes2_type_h4_r2
Lucas
russbost
posted on 27/10/15 at 10:51 AM |
Dominators & many projector lights have a flat topped beam pattern which is ok in both Uk & EU, I believe for EU countries "E"
marking is required (dominators are "E" marked, not all projectors are)
loony
posted on 27/10/15 at 12:33 PM |
It depends
Eg. in Poland flat topped beam is not permitted - one must have asymetrical beam (more to right side of the road)
Lucas
snowy2
posted on 29/10/15 at 07:48 PM |
Dominator dip "flat" so are a universal fit.....
sometimes you are the pigeon, most of the time the statue.
snowy2
posted on 29/10/15 at 07:54 PM |
I believe that the EU Has a rule that basically says that if a car is legal in one country it must be allowed as legal in another. ..it's how
HID lights are legal here in the UK despite not being allowed under C+U regs...
russbost
posted on 29/10/15 at 08:00 PM |
Oh, if only that were true - just try & import a perfectly legal kitcar registered in the UK to France, Germany or most of the rest of the EU
& see how much fun you'll have - the IVA is a national test, the only thing that is applied across EU has to be international, such as type
approval
