Author: Subject: Wtd Rover V8 Engine - but cheap
r1_pete
posted on 1/12/15 at 12:01 PM Reply With Quote
I'm looking for a cheap RV8 motor, in preparation for a future project.
I don't know what the project will be, but it will involve an RV8 hooked up to a modern manual box.
A generally worn out motor will do, as long as it hasn't thrown rods through the crankcase or similar.
Cheap is more important than condition at this stage, so if you're falling over one at the bottom of your garden and want to turn it into a little cash......
Cheers.
Pete.
bart
posted on 1/12/15 at 12:49 PM Reply With Quote
mistake
you appear to have made a mistake
what you actually want is a Chevy LS7 engine
for the price of an old rover v8
BE ALERT > BRITAIN NEEDS LERTS
posted on 1/12/15 at 03:43 PM Reply With Quote
Wow, can you point me in the direction of a Chevy lump for old Rv8 money?
Good job its not April but if they are the same price I'll have a 100 thanks!
Benzo
posted on 1/12/15 at 06:22 PM Reply With Quote
I have all the bits to build one in my shed.
Believed to be a ex TVR 3.9 engine with heads to fit, crank, rods, Pistons, inlet manifold, pair of SU carbs & sump.
If you have the hands to build it i don't have a need for the bits anymore so handy money will collect them.
One problem maybe be location as I'm N.Ireland Based but can pallet bits up.
[Edited on 1/12/15 by Benzo]
kenton
posted on 1/12/15 at 07:07 PM Reply With Quote
I have one sitting on a frame wired up to run. With lt77 5 speed attached.
Its a 3.5 inj taken from a SD1. I was going to use it in my build (v5 available) but then a twin plenum tom walkenshaw came my way.
I'm now using a new 4.6 V8 developments so both the above are no longer needed. Make me an offer if your interested.
Barkalarr
Contributor
Posts 942
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 1/12/15 at 08:43 PM Reply With Quote
I have one which needs some TLC - located in Ashford Kent if you're interested ?
marcjagman
posted on 7/12/15 at 03:28 PM Reply With Quote
Shame you're so far away, I'm looking for a V8 for my truck, bit of a hike though from Barnsley, unless it is amazingly cheap???????????
Chris_Xtreme
posted on 8/12/15 at 11:56 AM Reply With Quote
I've got a Rv8 block in the garage that I used for a sizing exercise.
no inlet stuff.
I would say it would need a rebuild. I was told it was from a running range rover. I think it is a 3.9.
I'm in New Malden, KT3 3EB.
Any use for anyone?
r1_pete
posted on 20/7/16 at 09:45 AM Reply With Quote
Still after an RV8, if anyone reasonably close (100 miles or so) to Sheffield has anything?
I've somewhere to put it now, in the 944
scudderfish
posted on 20/7/16 at 04:59 PM Reply With Quote
You might have better luck asking on http://www.v8forum.co.uk/
