Rena
posted on 18/2/16 at 10:24 AM |
Type 9 cap over speedo cable "outlet"
I´m not using the speedosensor on my type 9 gearbox.
I have seen on this forum a small cap that can be put on the speedo outlet but can´t find it anymore.
Suggestions?
peter030371
posted on 18/2/16 at 10:26 AM |
Not use one myself but I have seen these before. TYPE 9 AND ROCKET SPEEDO BLANK WITH O RING SEALS.
CATERHAM/WESTFIELD/KITCAR,Etc.
I really could do with something like that myself but £25 for a bolt that I can never see again makes me think twice!
Rena
posted on 18/2/16 at 11:27 AM |
I have seen that, but as you mentioned, £25 for that is too much
kingster996
posted on 18/2/16 at 11:37 AM |
I'll see if I can find the info - but I did read that you can remove the core plug on the other side, then remove entire drive, then use a
simple/nut/bolt/washer/seal to sort it - it's my plan over the weekend as my old box is out and new one due to go back in.
I used to be indecisive, but now I'm not so sure
peter030371
posted on 18/2/16 at 11:45 AM |
My box is on the bench with the old speedo drive already taken out....I had thought about a bolt/washer(sealant /nut solution but also interested if
anyone has done it before
posted on 18/2/16 at 11:46 AM |
On my type 9 I cut the speedo cable off close to the outlet and left it at that. It never leaked thereafter and I glued magnets onto the diff input
with a sensor on an alloy bracket over them to drive my speedo. IMHO chop the cable off and leave it be.
posted on 18/2/16 at 01:50 PM |
There is no real need to do anything -- just leave the driven gear and its' small oil seal in situ no cable .no cap required
peter030371
posted on 18/2/16 at 02:14 PM |
Mine doesn't have a gear just a hole that will leak oil My gear went to a friends gearbox that had a broken speedo gear!
big-vee-twin
posted on 18/2/16 at 05:39 PM |
Mine leaked oil so I cut the end off outer sheath of speedo cable, circlipped it in and sealed the end with RTV silicon
http://www.triangleltd.com
steve m
posted on 18/2/16 at 06:24 PM |
if your leaving the hole, put a small bolt and nut through it, with a tap washer each side, and some sealent
I meant HOLE !
[Edited on 18/2/16 by steve m]
peter030371
posted on 18/2/16 at 06:26 PM |
quote: Originally posted by steve m
if your leaving the whole, put a small bolt and nut through it, with a tap washer each side, and some sealent
Had a little look at lunch time with fresh eyes (!) and this is what I am going to do
richardm6994
posted on 19/2/16 at 03:47 PM |
I have read (either on locostbuilders or RHOCaR) that a 2p piece with a bit of silicon and the original circlip works well to blank off the speedo
outlet on a type 9.
[Edited on 19/2/16 by richardm6994]
J90rdn
posted on 21/2/16 at 10:21 PM |
BGH sell the caps for both sides for speedo drive delete. Bought these a few weeks ago and they just silicon in place. Looking at my receipt they seem
to be £5.60 plus VAT.
Rena
posted on 22/2/16 at 12:27 PM |
BGH?
J90rdn
posted on 22/2/16 at 12:46 PM |
BGH geartech. Try typing it in to Google
Rena
posted on 22/2/16 at 01:00 PM |
I tought it was abbreviation for something else.
