lordbenny
posted on 23/2/16 at 03:10 PM |
Really hard to start until it's connected to another car!
Zetec Westfield is really hard to start from cold. It's got a brand new BIG battery so I know it's not that, it turns over ok but just
keeps turning. It usually eventually starts up but today if just gave up until, on pressing the startebutton, I got nothing. As soon as I put the jump
leads on it fired up first time. What could this be? Dodgy starter?
HowardB
posted on 23/2/16 at 03:30 PM |
check the voltage drop on cranking, there was another thread on here not long ago asking similar questions,...
thread
and here too
hthmore
[Edited on 23/2/16 by HowardB]
Howard
benchmark51
posted on 23/2/16 at 04:45 PM |
Check the earth leads are tight and not getting warm when cranking. Try a jump cable from battery earth to starter body. Poor earth between engine and
chassis have caused this problem several times for me in the past.
AntonUK
posted on 23/2/16 at 05:50 PM |
I had a similar issue and after checking the above suggestions I pulled the starter open to find it full of crud. I cleaned it up and worked fine
afterwards.
Build Photos Here
Sam_68
posted on 23/2/16 at 07:23 PM |
Yep, this would be my first best guess, too.
paulc
posted on 23/2/16 at 09:54 PM |
I had a similar issue,
Turned out to be a build up of corrosion between the battery terminal and the cable clamp.
(look for a voltage between the terminal and the clamp when cranking)
Paul
garyo
posted on 24/2/16 at 09:08 AM |
Had a similar problem - turned out to be fuel pressure drop on cranking, and lack of non-return valve. Easy way to test is to manually earth the
injectors for half a second to fill the manifold with mist then try again. If it fires, then voltage drop/fuelling is the issue.
Did it ever work?
lordbenny
posted on 24/2/16 at 07:16 PM |
I'm going to get it rolling roaded in the spring....it's on carbs by the way....would they be able to adjust the static cranking voltage
when hooked up to the ecu?
Phil_1471
posted on 24/2/16 at 08:48 PM |
Sounds like an earth issue, check resistance from Earth terminal to various points with an decent ohm meter, or get a jump cable and Earth from
battery to engine block etc and see if that sorts it..
You can live in a car but can't rally a house
lordbenny
posted on 24/2/16 at 09:13 PM |
Going to try this at the weekend and get back to you all....thanks.
posted on 24/2/16 at 09:54 PM |
Not an unkown issue on Zetec transplants the problem is to do with EDIS giving too much advance at low speed for the Zetec due to a crank senor wiring
issue.
The cause is likely be the Vrs+ and Vrs- wires on the crankshaft variable reluctor position sensor are reversed. This results in a phase shift in the
sensor signal. The sensor should output a sine wave everytime a tooth passes the sensor but reversing the wires inverts it turning it into a cosine
wave shifting the ignition timing by 10 degrees.
https://www.autosportlabs.net/images/5/54/EDIS_system_diagram.png
lordbenny
posted on 24/2/16 at 10:53 PM |
issue.
Are you suggesting that I should swap the wires over?
Phil_1471
posted on 4/3/16 at 04:17 PM |
What was the verdict then?
lordbenny
posted on 4/3/16 at 09:17 PM |
That's a good question....I havnt cured the problem myself...it still is difficult start from cold. I am waiting for the weather to improve
before I take it to Novatech for a tune up. http://www.novatech.info/contactus.html
AlanH
posted on 4/3/16 at 10:39 PM |
I've got a similar problem and posted it recently. Poor cold starting on a pinto. Starts OK when warm.
Checked earth and that's OK. Need to check voltage drop on battery next then I'll check for a lazy starter.
lordbenny
posted on 5/3/16 at 11:19 AM |
I tried connecting a jump lead from the negative Earth on the battery to the starter motor and I also removed the earth terminal where it meets the
chassis and cleaned that up. I think my problem may lie in my start up procedure and the carbs. I have 45mm Dellortos so after turning on the fuel pum
and waiting for everything t fill up I give it three pumps. I then turn over the engine not touching the throttle....I MIGHT start then but if you
don't catch it, that's it's it! So, I'm now thinking it may be a carb issue. Will let you know once it's stopped
showing!
